Distributor - Locked Out or not?
Any advantages to locking out a mechanical advance distributor? Just curious.MSD Billet distributor with a 6CT Pro box in a dirt late model.
Imo, you are always better with some sort of advance mechanism, if only to make it easier to start.
I thought the same too but these crate engine builders are saying to lock them out!
If I had to guess, it's because it's a lower rpm engine and it's kinda dummy proof to keep someone from delaying advance too long or not advancing quickly enough. Starting a crate isn't the same monumental task of starting a gas engine at 15:1 compression either. Then there are boxes that naturally retard, even with a locked distributor and those that don't. Blanket advice is rarely ideal, but sometimes best.
In the end, the only goal on a crate is to get the most power out of it. You can dyno it and find the correct timing at every 1000 rpm, to make max power. Short of a programmable box, you are not going to maximize the timing curve. Locking the dizzy is safe. A curve that fully advances before your lowest on track rpm can't hurt anything.
Just another opinion but reliability of parts is way more important. Weights come apart, stick, rust, spring break and wear out, etc.......
I have saw a lot of broke starters with a locked out distributor , I personally like a centrifugal advance , I set my total where I want it and start it on 10 degrees , then put the weakest springs on it so it totals quickly , at rpm , its the same as being locked out and easier to start , JMO ....now the new drag race control boxes are a different animal ....
Locked out.
Wire your car so you can hit the starter to turn it over, then turn on the ignition.
