Results 1 to 15 of 15
    Sep 2020
    1,492
    Default Carrying the LF and its effect on aero
    I'm no scientist, but wouldn't carrying the LF through corners on a LM cause even greater downforce by having a larger wedge shape AND creating a vacuum of air under the left of the car that's no longer sealed to the track, therefore pulling the air down the side of the car rather than it going straight off?
    Batavia, OH
    13,667
    Quote Originally Posted by 84wedge View Post
    It lets more air under the car. That's bad. It causes lift. Now, with the yaw angle the cars have, it's not as big of an issue as it would be if the cars were straight.
    It would in theory let more of that air out, that enters under the center and right.
    A person would have to do some testing to be sure, now that I think about it.
    Thing is, you can't test that in a wind tunnel. You can't turn the cars in the correct yaw position.
    Sep 2020
    1,492
    Quote Originally Posted by MasterSbilt_Racer View Post
    It lets more air under the car. That's bad. It causes lift. Now, with the yaw angle the cars have, it's not as big of an issue as it would be if the cars were straight.It would in theory let more of that air out, that enters under the center and right. A person would have to do some testing to be sure, now that I think about it.Thing is, you can't test that in a wind tunnel. You can't turn the cars in the correct yaw position.
    But wouldn't the air getting under the car be on the left side only since the right side is sealed off to the track? In turn, it should redirect the air going across the top of the downward toward the track.
    Sep 2020
    1,492
    There is software out there that simulates computational fluid dynamics, but it's beyond a fan like myself.
    Batavia, OH
    13,667
    If it's under a surface, it's almost guaranteed to cause lift. It may only lift the left, but that's lift.
    If definitely doesn't seem to be as negative as air getting under the whole width of the car. You'd see that easily on the track.
  6. #6
    Sep 2020
    1,492
    If it's under a surface, it's almost guaranteed to cause lift. It may only lift the left, but that's lift.If definitely doesn't seem to be as negative as air getting under the whole width of the car. You'd see that easily on the track.
    So is there a possibility that what's going on with RTJs car in the corners is deliberately changing the aero to do this or is it just a suspension thing you think?
  7. #7
    Kansas
    1,942
    They are doing it for a suspension/loading reason, it's just not fully aero
  8. #8
    982
    My son says it is easier to roll that wheel than to carry it......you can not deny that statement
    We build fast race cars,,not race cars fast!
  9. #9
    May 2020
    4,788
    I saw what you did there on this thread!!!
    Nice trick starting new paragraphs. Instead of making long sentences.
    So nobody has to scroll to read your posts.
    You even went back and edited a post before post#4.
  10. #10
    Pittsburgh PA
    8,467
    Carrying the left front was a byproduct of terrible front end geometry. The only way it would help aerodynamically is if the valance still made it down to the track.
    Guerrilla Racing Junkies!
  11. #11
    Batavia, OH
    13,667
    Quote Originally Posted by Buford.Justice View Post
    I'm not sure what you are trying to imply, positive or negative.
  12. #12
    in a van down by the river
    1,893
    looks to me like a lot of stale/disturbed air in front of rear spoiler, at least on the surface of the decking.
  13. #13
    Jul 2007
    325
    Quote Originally Posted by JustAddDirt View Post
    There was a fad a while ago about drilling holes in the blade where it meets the deck and how it supposedly picked up down force. I think someone went as far as to detach it 1/2" or so all the way across
  14. #14
    Apr 2010
    856
    agree. seems like bead rolls running toward the deck would streamline it a little better. very interesting
  15. #15
    Feb 2017
    3,213
    Any air under the car is going to create lift, my neighbor rebuilds motors for slm and crates. He has been with a top team when they had there car in a wind tunnel. He mentioned the key area on these bodies today starts at that elephant ear on the RF.
