Sledge Hammer Ignition Setup
  • ep33510
    • 927
    The Sledge Hammer Ignition Setup
    This is only for that Serious Racer who takes pride in their racing program and wants only the very best possible performance solutions. If you’re currently running an MSD®Ignition 6 series analog box with a Blaster 2 coil. And if your competition has the same setup as yours, here’s your chance to take your program to the next level. Consider this; you could have access to a package that has the same foot print as a MSD®Ignition 6AL with a 30% greater energy output. With the matching coil this setup has made a major difference in all platforms tested. It does not matter if you are running a 9to1 engine or an all out Fire Breather you too can benefit from this upgrade! What does this mean to my program your asking, put simply this setup allows you access to the engine performance your builder gave you. You have always had it under the hood you just have never had accessed to it until Now!
    These systems were using are used (10 hours or less of run time) MSD®Ignition systems from a major racing series. Once we have them in house they are gone through and each ignition box is performance matched with the correct ignition coil for the best track results. The typical turnaround time once an order is placed runs 7 to 10 days. The cost to access this for your racing program for the 2014 racing season is $375.
    If you have any questions about this offer please feel free to contact us about it and how it can help your racing program.
    Pat Collins
    TechWest Racing Services
    MSD®Ignition Upgrade / Repair/ Technical Support
    8904 Sutherland Dr
    Huntersville,NC. 28078
    704-995-4286
    techwest@techwestracing.com
    www.techwestracing.com
