This set up is from a Nascar cup type car. Full size Quater Master magnesium bell housing. Quater Master 7 1/4 triple disc clutch pac with fine spline GM discs and light weight Quater Master 153 tooth flywheel. Thats right 153 tooth. Standard Ford flywheels are 157 or 162 tooth. This package was made to be used as a unit. High torque QM starter and Howe hydralic throw out bearing with fitting and #3 braided line. This bellhousing has increased ground clearance over stock bell and has GM bolt pattern for the transmission so it will accept Jerico, Muncie or Borg Warner type transmissions. This set up is straight off a cup motor. Would make an ideal street stock or modified application
500.00 obo 423-779-6126
