355 small block chevy 1550.00
  • jetmech
    • Oct 2009
    • 49
    For sale 355 Chevy just finished freshen up: Stock oil pan, stock crank shaft, new rod bearings, new main bearings, high volume pump, hardened steel oil pump shaft, stock 5.7 rods arp bolts, keith black claimer flat top pistons, new hastings piston rings file fit to KB specs, freshly honed cylinders, double roller timing chain, hyd camshaft from speedway motors p/n 915-110591 intake 480 lift ext 494 lift, double hump heads 2.02 intake 1.60 ext, new valve springs, screw in studs, cast iron highrise bowtie intake, all new gaskets, circle track valve covers, holley carb, holley fuel pump. >>>>>>>$1550.00<<<<<<<<<<< Greenwood, Indiana
