Stacked Springs
  • Ltemodel
    replied
    We start at a 600# top and 400# bottom and put 3/8" to 5/8" gap in the lock out ring at ride height. The best way to figure gap, if you can't test, is to record your RF dynamic ride height with your slick RF set up in. Usually you will soften RF for slick. Record your compression travel on the RF.
    Record your shock eye to eye measurement at ride height.
    Take your spring and shock off the car and put it into a spring rater and compress it to ride height and then dynamic ride height and record those two load readings.
    This will give you the load the spring is supporting at its maximum in the corner and load at ride height.
    Then stack up your springs with the lock out and adjust them so that your spring eye to eye measurement and your load at ride height come back to the original measurements.
    Then you can compress it and start playing around with the dynamic side.
    If you want to raise the RF ride height in the middle of the corner, take gap out of your lock out adjuster.
    If you want more travel on to the RF before it stops, put a larger gap into your RF setup.
    This set up is not a cure all deal. It is good if you know how to work with it. Experiment and have fun.
    Kevin
    Leave a comment:
  • CHUMBA
    replied
    thats funny 2 years ago I ask him about doul stage stack spring on right front and he said he knew nothing about it. that was after I spent around $1000.00 getting shocks repaired & revalved.
    Leave a comment:
  • BDR40
    replied
    A lot of guys run around a 400-600# 4 inch spring with anywhere from a 350-450# 8 inch spring on the dual stage stuff. Brian @ Integra recommended that we start with a 600/400# to start out.
    Leave a comment:
  • CHUMBA
    replied
    Not calling you a smart ass!!! Just trying to get as much info as I can. we have ran it our last three races, and are going to continue to work with it, I think we have figured out we are running too much gap, thats the only direction we have been adj, when we start raceing again we are going to go less gap, but that will be in april 2012. so Iam just trying to learn more about the complete set up so we can be close. thank you for info, and again sorry for implying you were a smart ass, not my intention!!
    Chumba.
    Leave a comment:
  • rcmaster
    replied
    not trying to be smart,it just takes testing, every driver is different,how much rebound you run in right front makes huge difference, most people will try it and run it if it works that night if not they wont adjust it just take it off.one last thing figure out how much rf travel your car gets when its at its best then make sure your stack gets same travel then adjust to liking--------- its really difficult to explain all the different adjustments.
    Leave a comment:
  • CHUMBA
    replied
    Teach us old wise one! thats why Iam asking questions on here trying to learn, dont have budget to travel 4 hours rent track and just try things, I have called chassie builder, he dosent run it. and wont give advise on it! PM me if your are interested in helping. CHUMBA
    Leave a comment:
  • rcmaster
    replied
    Originally posted by CHUMBA View Post
    PMs cleared, I think
    you guys have alot to learn, hypercoil will get you lentgh you need, get you a checker and check stack rates with different nut settings,you will be shocked, and when you run it make sure you have a travel indicator on outside of shock.
    Leave a comment:
  • CHUMBA
    replied
    Leave a comment:
  • mackwrench
    replied
    STACKED SPRING RATES
    400 / 175 = 122
    400 / 200 = 133
    400 / 225 = 144
    400 / 250 = 154
    400 / 275 = 163
    400 / 300 = 171
    400 / 325 = 179
    400 / 375 = 194
    400 / 400 = 200
    Formula:
    Top spring Top spring
    X (divided by) + = Total Spring Rate
    Bottom spring Bottom spring
    Example:
    400 X 225 = 90,000
    400 + 225 = 625
    90,000 divided by 625 = 144
    Leave a comment:
  • Sprint76
    replied
    Chumba, clear your PMs.
    Leave a comment:
  • CHUMBA
    replied
    Please explane how this combo would work?? I dont get the 600 on top of the 500. pm me if you dont want the whole world knowing. thanks chumba.
    Leave a comment:
  • giffordracing
    replied
    600 4 inch top
    500 8 inch bottom
    Leave a comment:
  • CHUMBA
    replied
    grt74 you got PM
    Leave a comment:
  • grt74
    replied
    chumba,use two 7in springs,you may have to work a little to get them on but they will go on by hand,we use hypercoil springs on ohlins shocks or a 7 and a 5 or 6 and a 4in spring i would not worry about the coil bind because it should hit the lock nut before coil bind if adjusted right but you can always check it on a shock/spring rater before putting it on the car
    Leave a comment:
  • CHUMBA
    replied
    We have but the more I stiffin the bottom the closer the top 400 5" spring is getting to coil bind, if I go to a 6" long spring I cant get the bottom cone on. Thats why I was asking about spring compresser. anyone know of anyone making one? or a way to get the spring compressed to get cone on? Thanks again for all replys.
    Leave a comment:
