Help with 2004 Pierce Clamp
  • stalker1998
    • Jan 2013
    • 4
    Having problems with setting the rear end from side to side. I recently bent the rear clip to the right, exactly where the shocks mount. I realized it when I went to set the left rear shock at 15 degrees and the RR was inline with the RF. I was planning on centering the rear end and just moving the upper shock mounts. What’s the best way to center the rear without using the shock angles? And what should the RR shock angle be when the LR shock is set at 15 degree on a spring infront clamped up? Thanks
  • anissa5
    • Jul 2010
    • 79
    Pierce
    Line up left side wheels with 2in offsets
    • stalker1998
      • Jan 2013
      • 4
      Thank you!
      • racer69
        • Apr 2009
        • 249
        ^^^ yep! Line up left side and get your new measurements.
