01 Mastersbilt left rear adjustment
does mastersbilt make an adapter plate to change from four hole adjustment to a seven hole? something like rockets long to short bar plate.
i'll sell ya kit for it, it contains as follows
steel plate
qty of 1, 5/8" drill bit
$300
how much does it shorten the bars, what effect does it have in the rough conditions, what bar angle do the holes need to be located?
lazermod3
steel plate
$300
That kit wouldn't work. The holes are 1/2" on the 7-hole plates. 5/8" holes were used on the 4-hole plates.
Mastersbilt will sell you the hardware if you want to weld everything up yourself. Unless you know what you're doing, I wouldn't go fabricating the plates since you won't know where the holes need to be. It doesn't change anything in terms of bar length, just gives you more adjustability.
If you're looking for setup info, check the setup sheets:
http://mastersbilt.com/setups/5010.pdf
