Results 1 to 5 of 5
    Oct 2007
    Winona MS
    94
    Default Someone Please help me. Rear Suspension
    What is the longest spring I can use on a metric car with stock spring mounts? I really wanted to try the 20" but I just cant see it compressing enough to fit. I run a 250lb
    11" spring on the lr and a 200lb on the right. I am completely unloading the left rear. If I run the longer spring what would you suggest the spring rate be. I know if I run the same rates Ill only change ride height. I dont have tons of money to just buy several springs and not be in the ball park. Can someone please give me a relative starting point? If I were to run a longer spring on the left would I have to do the same to the right? Thanks.
    Oct 2007
    904
    how much does your car weigh ? you should be able to get a 16" 125-150 in there if you are 3200+, honestly i have never messed with the longer springs with stock spring mounts, but im making an edumakated guess based off my experience with the 20" 100
    Oct 2007
    Winona MS
    94
    Car weighs 3500 pounds. Do i only use the longer spring on the lr? I was thinking that I should only do it on the left rear. I dont think I want the "Jack in the Box effect" on the right rear. Is my thinking correct? Anyone know how much spring rate increase ill get by preloading say a 100lb spring, say 3 inches.
    150
    Bradley
    Check your personal messages
    dirt2
    May 2010
    632
    A 100lb spring with 300lb on it will compress 3 inches
    A 250 lb spring with 300 lb on it will compress 1.2 inches
    So if your 250lb spring compresses 3 inches it has 750 lb on it.
    A 100 lb spring with 750 lb on it will compress 7.5 inches.
    If you have more then 3 inches rebound on LR, yes, a longer, lighter spring will work for you. I always used 13 inch springs and going to a lighter spring worked for me. An 11 inch spring would go into coil bind, i would think.
