mustang lower control arm
I have a 1980 model foxbody mustang and I was wanting to know if they are a longer lower control out there so I can get a little more camber. I already have caster camber plates but I can only get -4 camber on the right side and it isnt enough.
Rules permitting, add some length to the lower arm? -84Dave-
I've heard '89 and up the lower right a-arm is longer. I don't know for sure but maybe someone on here can answer if it's true.
The T bird lower will work too. It is longer.
dr6 motorsports
95 and up lca's are 1 inch longer and yields roughly 6 degrees of negative camber, with a stock type upper strut towers.
mark41
stock fox body is 13" from centerline to ball joint center the 89 svo has 14" center to center and i believe the tbird is 13 3/4
Miller
