filter
Cut filter apart to see if blew the media to shreads. If it did that will back up pressure in the filter and blow the rubber seal out.
I have had that happen with a Fram PH8A on my mustang street-strip toy. they are junk.
try a Motorcraft FL1a. ,it is a better filter with better media.
that should be the equivelent to the fram PH8a
NEVER use a Fram on anything preformance oriented.
That would be were I start.
but run a wix racing filter, and you will b just fine
