losing oil pressure in corner
I have an oil pressure problem that occurs when im in the corners. Car likes to 3 wheel in the corners and that's when I'm seeing the problem. Any ideas besides the obvious don't 3 wheel? The motor is a 406 sbc wet sump with a moroso racing pan. Thanks
Master X
not a fan of moroso pans i would look into getting a better pan champ pans work good.
Ditto for the champ pans!
»»*†HÀ†§ HÓ††™««
Sounds like oil is taking to long to make it back down. Do you run restrictors? Maybe throw an extra half quart in?
