Results 1 to 7 of 7
Thread: clearance
    May 2013
    19
    Default clearance
    What is the correct clearance between rocker arm and cam when lifter is fully collapsed.
    Jul 2007
    154
    .035"-.045"
    May 2013
    19
    Best lifter to use?
    May 2013
    19
    Having trouble with head setup all together a walkthrough would be greatly appreciated
    Nov 2013
    5
    Check out Esslinger engineering look in there tech sheets it takes a good day or more to set it up right. Most machine shops can't set up a 2.3 cylinder head right! I will set it up for a $150
    May 2013
    19
    I will check into it anyone else have comments or consideration
    May 2013
    19
    Any truth to .005 under the rockers on hla's?
Tags for this Thread
