Escort Caliper Brackets
Anyone know where to get Escort Caliper Brackets for the Ford 7.5 rearend? I have tried to get ahold of FLYNBRYN but no luck.
www.raceidaho.com
why are you using escort break brackets?
This is a fairly popular brake upgrade for the Fox Mustang rear brakes for Oval track racing. The person Eric was trying to reach used to sell a kit to mount & install them.
JerryM
will they fit my mustang if I go get them out of the junk yard?
no,these are weld on brackets that you weld to the rearend housing
www.raceidaho.com
ok...any brake gurus out there that can point me in the right direction?
1986 fox body mustang with manual brake adaper in firewall,Wilwood Tandem Master 7/8 bore, part number 260-9439...front brakes are all stock with new calipers and cross drilled and slotted rotors,all new metal lines to wilwood proportioning valve right next to driver,then back to new 1989 escort front calipers on escort cross drilled and slotted rotors.
we can get full front brakes,but no rear brakes,we have replaced all lines, all fittings,everything is inverted flare fittings to double flare lines,the escort calipers originally took a banjo fitting,so re-tapped them to a 3/8-24 and screwed in a female inverted flare, then ran the rear lines into those,no matter what we try,we cannot get rear brakes,we are over a month into this battle and so far have went through over 2 gallons of brake fluid,used the old fashioned method of someone pumping brakes,then crack bleeder,also used a vacuum pump,then an air powered vacuum pump,then a phoenix brake injection system...have had the same results with 3 different stock masters,and now this wilwood master,also eliminated the factory distribution block and residual valve,so the primary line from master goes to a T which then goes to RF and LF brakes,the rear(secondary) then goes to wilwood proportioning valve then to rearend,then out to escort calipers,have tried bypassing proportioning valve with same results,also tried switching the rears to the front to see if master was the issue,no such luck...PLEASE HELP..i have been pulling my hair out over this issue.
Sincerely, Going Bald in Idaho
www.raceidaho.com
do you have fluid at the rear calipers? Does the master sit level or is the front higher than rear?
Have you tried using a brake pressure gauge to determine if there is the appropiate pressure at the rear brakes? It may help point you in the right direction. Even though the front brakes seem to be working there may be something in the line going to the rear brakes preventing them from getting the correct pressure. It is worth the time to help isolate the problem. Someone near you must have a brake bias gauge setup.
yes there is fluid at the rear calpers,bleeder valve is the highest point on the rears,master sits level
www.raceidaho.com
If your absolutely sure you have removed all air, and sounds like you are, then I am going to give you the same advice I gave you on your other thread about this. Get the residual pressure valve from my earlier post. Place it at the master cylinder. I know what wildwood and the other "experts" say. I have had this same issue before and little valve is like magic.
you can also install a pressure gauge in the bleed hole and see if you are getting the proper pressure. If you have normal pressure look at the calipers. If you are using used parts that you don't know the history of, make sure the pistons move and are not frozen in the bore.
so put a 2psi valve right at the master for the rear brakes? or should i get 2 of them and do it at both the front and rear?
www.raceidaho.com
Since you have front brakes, and don't have rear brakes, for now just the rear. You should check the pressure at the caliper first though. You didn't answer if you have used calipers......
You could start off by just putting one on the rear line but i would do both at same time (front and rear) so you don't have to do it later. Yea 2# are for disc brakes.
Daniel #27 mini stock
oh sorry,yes EVERYTHING is brand new
www.raceidaho.com
Where did you find your rear caliper mounts at?
www.raceidaho.com
no it didnt,i tried both a 2psi and 10psi...we were able to block off the RR and that gave us enough brakes to actually make the 1st race,but really need that 4th brake...same results with blocking off the LR,so even though rearend is welded,we figured block off the RR brake and go race for now...i feel like maybe the 7/8 master isnt big enough??
www.raceidaho.com
You just might try reading up on how to properly size a mater cylinder to your calipers that you have and to set up the proper leverage that is needed.
https://www.markwilliams.com/braketech.aspx
