Mini Stock Parts List Complete Sell Out Make Offer
Everything has to go. Sold my car and this is everything else I had. I put prices on some stuff and some stuff I didn't but if you see some you want give me a reasonable offer for it and its yours. All parts are located in Lutts, TN. For more info call or text 256.740.1823
Parts for 2.3L Ford Mustang Mini-Stock
2- Black Gabriel Struts $30.00 for both
2-Gabriel Red Rider Shocks $15.00 for both
1- Lightweight Mustang Front end complete with A arms and hubs $40.00
1- set of 3.27 gears for 8.8’’ rear end $20.00
1- set of 3.73 gears for 7.5’’ mustang rear end $20.00
Racing Springs $10.00 ea.
1- 5x9¼ 700# 1-5x11 650# 1-5x8 250# 2-5x11¾ 900# 1-5½x12 pigtail 150# 1-5½x12 pigtail 225#
2- Racing Electric Fans $20.00 ea.
2- 2.3L Ford Oval Port Carburetor Intakes $10.00 ea.
1- 19” x 32” Howe Aluminum Radiator $40.00
2- New Model Mustang Distributors (No Brain Box) with New Accel Performance Control Modules $40.00 ea.
1- 9”x2” Rechargeable Air Filter with top & base $15.00
1- 5 quart stock type oil pans (steel) w/ pickup $15.00
1= Square Tooth Aux. Shaft Pulley, Crank Pulley, Belt, & Belt Tensioner $15.00 For All
1- Set of Hypereutectic Flat Top Pistons bored .40 over with 5.2” Rods $100.00
1- Ovalport open Chamber Hydraulic Lift Head with Ovalport Intake and Valve Cover Has been milled about .125 thousandths No porting or polishing Oversized valves, stock type valve springs, & Rhodes lifters will pull vacuum ready to race bolt on and go $200.00
2- Spring Rubbers $5.00 for both
1- Mechanical Fuel Pump $5.00
1-Electric Fuel Pump $10.00
1- Water Pump Pulley and Crankshaft Pulley w/belt single groove $25.00
1- Racing Radiator Cap $5.00
1- 5 blade Aluminum Fan w/spacer $10.00
1-5 blade Plastic Fan $5.00
2- Thermostat Housing $10.00 ea
2- Used Water Pumps MAKE OFFER
8- 765 Autolite sparkplugs MAKE OFFER
1- Motorcraft Oil Filter FL-1A Brand New MAKE OFFER
9- ½ Fine Thread 1” Oversized Lugnuts 5 Brand New 4 Used MAKE OFFER
TOOLS
2- 5 gal. Racing Fuel Jugs $15.00 ea
1- Racing Fuel Funnel $10.00
1- Esslinger E-Bar $10.00
1- Vacuum Gauge $10.00
1- Compression Tester $10.00
1- Holley Jet Kit $20.00
1- Actron Digital Timing Light $50.00
Safety Equipment
1- Pair Simpson Stealth Driving Shoes Size 13 (Black) $40.00
1- Simpson Neck Brace (Black)$15.00
1- Pair Driver X Gloves Size L (Black) $30.00
1- Pair Simpson Seat Belt Pads(Blue) $15.00
1- Safety Racing One Piece 2 Layer Driving Suit XL (Blue) $30.00
1- Worth One Piece 1 Layer Driving Suit M (White) $5.00
1- Leaf Racewear Pants 1 Layer L (Black) $15.00
1- Leaf Racewear Jacket 1 Layer XL (Red) $15.00
1- RCI Racewear Pants one Layer S (Black) $15.00
Pair R&L Butlerbuilt Head Supports w/black cover $20.00
I still have just about everything if you r interested in anything call me or text me and lets make a deal.
