Results 1 to 4 of 4
Thread: 05 smackdown
    Default 05 smackdown
    Car is tight getting in and loose coming off turn with no forward drive starts spinning once it gets on straight and using all the rf shock causing the rail to drag. Any one have any suggestions? Lf 450 rf 425 lr 225 rr 225 integra non-adjustable gas shocks 75 lbs all around lrf 125 lbs ,ls 54% rear 53% 95 lbs bite s7 spindals 17 5/8 rf lower jbar 8" on frame and center of pinion 5th coil 325 1/2" preload 2nd hole from end of lift bar 7 hole 4 link brackets on rear, ride heights Lf 3 3/4" rf 3 1/2" lr 8" rr 7 1/2"
    Jun 2007
    3,123
    Where are your 4-bars on the frame?
    You might consider a softer RF to help turn in better.
    Lower bars are 3 holes from bottom lr top bar 4holes up rr bar 5 hole up.what would raising rf ride height 1/4" soften spring and raise lr ride height 1/4" and go to a 200 lr spring do?
    what type of track is it
    whats the length of your rear bars
    how hard are you on the rr maybe go to a 200 to free entry up
    how much rebound do you have in 5th coil shock
