FORD 410W Complete Steel Wet Sump Engine
Steel 410" Windsor .040 over block Engine with steel girdle ,ARP studs & Bolts through out & newest casting N351 cast iron 10* heads with 2.055 x 1.60 s/s pro-flow valves ,Jesel shaft rockers ,Comp. Cams. solid roller cam,lifters ,polished springs,titainium retainers & locks. 4" Callies billet crank & 6.25 Callies H-beam rods ,Mahle Forged FT pistons & rings,internal balance Inovaters West steel balancer ,Edelbrock Victor water pump,Edelbrock Super Victor Intake,MSD pro dist. ,Taylor 10.2 wires,Melling oil pump & HD shaft ,7qt. Kevco front sump pan & p/u tube. 570hp on 110 octane gas with 750HP Holley & 555hp with 650 2bbl ! $6,000.00 cash .Also Avalible with Brinn Mag tranny & Bert aluminum bell,starter,couplers for $,7500.00 (GREAT FOR LIMITED LATE MODEL ,STEELBLOCK LATE MODEL,MODIFIED ,SUPER STOCK,PRO STOCK,OUTLAW STOCK ) Seller Phone Number: 724-880-4580
Tags for this Thread
