camaro front end parts.
Do you guys know where I can get OEM camaro front end parts or what else I could use ? Thank You
A local parts store can get your basics (tie rods, drag link, balljoints, pitman arms, idler arms, steering box, bushings, etc..) . Spindles and stock upper and lower control arms you can find either at a junkyard or on Speedway or other online racing outlets. Some parts stores can special order spindles and control arms in but we never had much luck when we used to run a camaro.
#72W U.M.P Stock Car
Thats all you guys have to say ? Come on , help me out here.
just about ant full bodied gm car parts work....
What year Camaro?
Go find a Hollander Interchange manual, will tell you what parts are the same for different cars. The 50th edition covers early 70s to early 80s.
If it's an 80/81 Camaro, the 80s Caprice spindles and arms should be the same.
