Results 1 to 12 of 12
Thread: chalk on tires
    Default chalk on tires
    can anyone explain to me why I see some cars with chalk going around the circumference of the steer tires? Thanks.
    Sep 2009
    832
    A place to measure from to set toe.
    Accurate toe adjustment.
    Oct 2014
    22
    Checking radial run out.
    Jul 2014
    305
    It's what the cool kids do 👍
    Jan 2014
    253
    So a crew member can make an education assumption of the steering input the driver is using. Other methods of getting an educated idea of steering input rely upon data acquisition and feed back from the driver that keeps in memory the location of a piece of tape on the steering wheel during cornering
    Find me on Facebook: Impetus Dirt Racing Technologies
    Feb 2008
    colchester il.
    2,172
    we use white spray paint around the centerline of each tire you will also need a tire scribe like in the photos below to scribe the centerline the paint simply makes the scribed line show up better. now you can measure the distance between each tires center to get a true toe reading. with bump gages your ready comes from the side wall of the tire which can be incorrect due to bent rims or bad tires but it is the most common way due to how much easier it is.
    Sep 2009
    832
    A jack stand and a piece of chalk works well too. OR a nail in a 2x4 for a scribe.
    "So a crew member can make an education assumption of the steering input the driver is using" I wanna hire this crew member that can see that chalk line at 120 mph!! LMFAO!!!
  10. #10
    Jul 2008
    545
    Not to mention it's gone by the time the track is packed in.
  11. #11
    tulsa america
    2,687
    Quote Originally Posted by charcoal01 View Post
    yeah they had me scratching my head at that one...
  12. #12
    Jul 2014
    305
    Ya uh no it's not for stewing input haha. But I'm hoping hat was the joke of the day. 👍It's simply for alignment or if lined on side of tire used for tire/rim slippage. Usually not chalk though a me he line is usually spray paint scribed. Haha good rear for my Friday 😂
