MOTOWN 400 complete
FRESH Standard bore Motown 400 splade caps, steel GM crank, 6 inch eagle rods, 15:1 JE pistons, all ARP Bolts. RHS heads with studs, big springs, roller rockers, stud girdle, Howard's flat tap cam with specs, new gear and chain, Motown Intake. Also comes with CV fuel pump (was over $300 new), Kick out pan, aluminum racing water pump with pullys and four bladed fan, HEI distributor with MSD chip. THis is engine is fresh right down to the Brad Penn Oil and New WIX racing filter. No carburetor. Do have willy's four barrel for additional cost. Jacksonville Il. Text 217-370-2011
Can start it on the stand with notice.
No Junk Here $4500
