Results 1 to 5 of 5
    Default Cam identification
    Any help identifying this cam?
    Crane XG 272/320-12
    19 37 92
    Thanks
    According to the Crane catalog the pattern looks like-
    duration(272) / lift(320)?? / lobe separation(112)
    I assume 193792 is the grind#.
    I don't see anything close to these specs and Crane couldn't help either.
    Illinois
    1,690
    The duration & lobe numbers look right for an aftermarket HP cam but the .320 lift cant be right. Bone stock OEM cams are .390-.410 range depending on year.
    320 could be the cam lift. .320 cam lift with a 1.6 rocker ratio will yield about .510 total valve lift.
    Thanks Jb35. They got a new cam ordered so they would know exactly what they are dealing with..
