Results 1 to 10 of 10
Thread: crates on alky
    Feb 2009
    117
    Default crates on alky
    what needs to be done to switch a crate motor to alky besides carb
    Pa
    486
    I don't think you can run Alky in a motor with hypereutectic pistons that come in a crate motor unless they were changed for aluminum pistons.
    Jun 2007
    3,123
    Always a concern with running alky is burn-off. It's hard to keep your car balanced through a race because you burn off so much more rear weight with alky versus gas. That coupled with the fact that it is already difficult to get enough rear weight into a crate car without being over weight is why most people avoid it.
    Different carb and you're going to need a pump made for alcohol also. Alcohol pumps are usually belt driven to accommodate the varying fuel pressures required and you'll almost always want a regulator also.
    Jul 2007
    3,224
    Quote Originally Posted by lovinlatemodels View Post
    Hundreds being ran in IMCA modifieds on alky now with no issues.
    2,319
    Carb setup for the fuel and a decent pump like the Procam and a regulator. No big deal at all. A crate will run fine on alky.
    BUCKLE UP NOW, YA HEAR?
    Oct 2007
    974
    we intially had some concerns with our 602 sprint program being it has a basic cast piston----however after thousands of laps and many different levels of maintenance amongst teams---we have yet to have a piston failure
    no worries at all on a 604
    to answer the original question
    as Matt said ----carb --fuel pump and regulator
    I will add that proper size of fuel lines and also test your fuel cell foam or just change it now with a foam that is alcohol approved
    Brad
    Feb 2009
    117
    thanks I was wandering if I had to change the fuel pump or not some say yea some say no
    Jun 2007
    1,047
    I would say yes on the pump unless you're using a belt drive or alcohol pump on gas. I'd let the people that say no have at it on their car. The right way is always the cheapest, fastest and easiest way.
    Feb 2009
    117
    had car on alky this past weekend and we used same manual pump and just put alky carb on and changed fuel filter and so far he ran it bout 35 laps and ran perfect
  10. #10
    Jun 2007
    1,047
    Usually the pump will have too much pressure at idle and not enough wide open if you are on a bigger track, and they break frequently. That's why people run belt drive pumps. If it works for you, that's good.
