18 Degree 358 Tour Mod. Engine
I have a very nice 358. 18 degree GM Performance Parts aluminum heads,CNC ported and polished, Bowtie GM Performance Parts steel block, Crower small journal 42lb crankshaft, Carrillo 6" billet rods, Jesel valve train, Peterson 5 stage dry sump pump and braided lines, Stainless steel drysump pan and braided lines, MSD dual pick up billet distributor with Moroso wires, all aluminum CV Products pulleys and mandrals, Aluminum oiling valve covers with breathers, adjustable #20 water neck, 1" CV Products 4 hole spacer. Engine is very strong and made over 700hp on the dyno with a 830cfm carb. and 631 with Nascar 390cfm. Engine is fresh and ready to drop in. $10,000.00 Engine located in Virginia. 434-531-1736 Great for Nascar Southern/Northern Tour Mods, K&N series, Dirt Late Models etc.
