Results 1 to 5 of 5
    Jan 2008
    6
    Default Complete Sell Out
    Pierce 3-hole clamp car rear suspension with complete tubular frame. Full containment 13" Bulterbuilt seat, Engine is Ford 2.3L 4-cylinder, Hyd cam, Holley 350 CFM 2 brl Stealth Carb,Frankin Quickchange ,Bert trans, metric spindles,upper and lower tubular a-frames, Sweet Rack, Mel's Ignition, Afco Alum. Radiator, New Header ,Esslinger Water pump,Adjustable Timing belt,Lightweight fan,New 12 gallon Fuel cell.Comes with spares, 3 extra heads, 3-short blocks (disassembled), 2 intakes and other engine components , complete Mel's ignition system some other suspension parts and spare wheels with used tires. All bolt on components are based off standard Pierce car. 2014 and 2015 KidModz Championship car. Complete operation buy today and race it tomorrow. $6,500.00 OBO. 314-406-2540 Will consider trades for Modified equipment.
    http://www.kidmodz.com
    http://www.ryanhamiltonracing.com
    Colorado
    323
    Is this a full size modified type chassis of something cut down.
    Jan 2014
    5
    it is full size, however the front is tubular not stock stub
    Feb 2008
    2
    Would you sell any of the parts separate
    Jan 2014
    5
    What parts are you referring to?
