Results 1 to 14 of 14
Thread: A40s
    Jun 2013
    7
    Default A40s
    Anyone else having problems with the 2nd tread in from the outside chunking out. It is only that row. After a 8 lap heat the tread raises and is spongy like the rubber is blistering at the base of the tire. By the end of a feature it has nearly the whole 2nd row chunked out. We are starting with 13-14psi and siping less than 1/8" deep. Seems that its worse when there is moisture in the track. Any thoughts/advice would be appreciated cause this is getting expensive.
    495
    Quit siping
    Aug 2016
    9
    yep ,don't sipe, especially on fast tracks.. but you don't need to sipe A40S...maybe after 4 or 5 nights on a right rear
    Sep 2013
    231
    not having these issues. agreed - i'd stop siping
    Nov 2007
    509
    Raise the air pressure a couple lbs.
    Don't sipe
    in a van down by the river
    1,892
    I only sipe them if they harden up a bit, or I have moved them to the front of car.
    I would NEVER run one on the RR.
    if it run them on the LR new, I never sipe them.
    tulsa america
    2,686
    what do one of these punch new?
    1,892
    I have seen 40-50 new .
    kind of a wide range.
  10. #10
    Like everyone said, quit siping. It tears the a40s apart. Its also trash on the right rear anyway. Bolt on an H.
  11. #11
    1,892
    Default a40s
    Quote Originally Posted by langdonracing48 View Post
    exactly.
    The feel really mushy on the RR to me. car is real squirmy. I have only tried them on a slower track on RR and do not like feeling.
    I Really like the H on the RR at all times. just have to know how to get them to fire quick.
  12. #12
    tulsa america
    2,686
    Quote Originally Posted by JustAddDirt View Post
    exactly.
    Even for 2 laps at the gateway nationals?
  13. #13
    1,892
    Default tires
    Quote Originally Posted by powerslide View Post
    maybe an exception there, especially early in night. I don't think that track will be really fast. but if it gets hard and slick, I would put on an H without a doubt
  14. #14
    Jun 2007
    570
    Hoosier told me to only sipe a new tire, less than 1/32 deep and only one time. helps the rubber to cure and harden. heat soak tire before racing it.
