Results 1 to 4 of 4
Thread: Half Leaf
    Jun 2007
    570
    Default Half Leaf
    Looking for some info on running a half leaf, plus coil setup on a mod. Its an older car
    Feb 2008
    8
    Ran this set up under multiple cars. on a mod id go 225lr 175 rr lr spring ahead -rr spring behind but need a panhard bar behind rear end to work well. best set up is to make clamps on half leafs, mount coil over eliminator on leaf like a swing arm. make short behind rear end panhard bar that mounts in same location as j-bar-very forgiving and has won a lot against three link cars
    Mar 2013
    196
    ran a WT harris with this setup worked well a ton of fwd bite. Was the car built with half leaf or are you switching ?
    Jun 2007
    570
    was going to buy, but decided not too
