Rocket Blue Grey setup questions
We have a 2014/2015 Rocket Blue Grey. The basic setup is ok but when it's really slick or wet we struggle. Rocket says on a dry track to lower Rf and raise lr. This helps some but I am just curious. Are guys lowering the right side bars on a slick track. Or shortening the bars on the right side. Taking stagger out? We run about 3.5 to 4 rear stagger
BSW75
It depends on what you are trying to correct. Both of those adjustments can be correct under the right situations.
"when it's really slick or wet we struggle" Explain, True Super Late? Track and/or track configuration surface. Tires?
Super late model. Standard setup is ok. But when it gets really slick we lack coward bite from center off. Lm40 tires
