Results 1 to 3 of 3
Thread: motor question
    Dec 2007
    643
    Default motor question
    got my motor back put timing light on it the mark on the balancer is jumping so much i can't set the timing what could be wrong? i have a cloyes 2 piece cover on it, msd 8552 dist. never had this problem before i had it rebuilt any suggestions on what i may have done wrong? thanks
    Oct 2007
    205
    Cam walk.
    Check it at about 3000 rpm and see if it stops moving.
    Nov 2012
    Wisconsin
    3,119
    Cam walk, loose outer ring on balancer. Sometimes a cheap neon timing light works better on an MSD system.
    Class of 2019
