Results 1 to 3 of 3
Thread: clamped set up
    Sep 2007
    12
    Default clamped set up
    on todays cars What is clamped to what and is it all clamped to the tube. I'm getting back into racing and years ago I ran everything clamped together and clamped to the tube but I don't see how that works with a pull bar. I ran a lift bar but kept zero preload on the 5th coil.
    Oct 2018
    482
    You want your shock and spring bolted to the birdcage.
    Nov 2007
    205
    For most 4link/4link pullbar setup, birdcage, with links attached, floats on axle.
    Brakes can be clamped to axle, on a floater with its own link, or attached to birdcage.
    Most common, lr spring behind, shock in front attached to birdcage. RR spring and shock on front of birdcage.
