2013 pierce
2013 Pierce Latemodel. 100 laps on new build-steering components, 28 gal certified fuel cell, fire system, 18 inch containment seat and belts, steering wheel, drive shaft, door plates, clutch master cylinder, optima battery, fuel lines + filter, msd coil, double msd ignition boxes, headers, j bar, fifth arm, complete rebuild on quick change with new -bird cages, rotors, brakes, bearings, body with spring steel bracing, fan, starter, wiring, front and rear bumpers.
Car has afco double adjustable canister shocks, double pass radiator, bert transmission and bell housing.
engine- 18 degree 415 built by Friedman Race Engines. Dart shp pro billet block, edelbrock heads and intake fully ported, comp cam, bam bushed lifters, jesel shaft rockers, lunati crank, dyers rods, olson 10 qt oil pan, ati balancer, allstar pulleys and water pump, titanium valves, msd billet distributor, multi-fire plug wires, cv billet fuel pump, moroso valve covers, je pistons and pins, melling oil pump, cloys timing set.
car assembly and engine build summer of 2019 at dyers rods. Car assembled by Daren Friedman. 100 laps since. car is straight, never bent. selling due to health reasons. Some extra tires, wheels, and misc parts included.
$24,000 turnkey
$13,500 just engine
$10,500 roller (less engine trans bell housing starter)
Selling for Mike McGuire. Located in Forrest, Illinois. Contact Mike at 815-848-8507
motor is now out. mike said 8500 roller 9500 with trans, bell and starter. car was also UMP and WOO legal.
thank you
mike wants to move the car and motor. all reasonable offers considered.
mike wants to move this out, taking reasonable offers, car is straight, has not been raced but a few years on frame, most all new parts.
6500 roller and all spare parts. mike says sell
