Results 1 to 10 of 10
    Nov 2019
    michigan
    2
    Default hole in fuel bladder
    we have a little hole in fuel bladder of xr1 is there a quick fix until we get a new one ? a patch or something
    Sep 2009
    831
    Plastic liner? I wouldn't be able to recommend drilling out the hole to 5/8 and pulling a tire valve through it. From the outside in so it still fits in the can. I can't say i've ever done that or anything.
    If it's a crack, I wouldn't even think about epoxy resin made for boat repairs.
    Oct 2017
    1,368
    Their is a repair kit but it will only work if it's a hole from damage. If it's a white bladder and has had alcohol run in it that is the first of many holes and you need a new bladder. They make one for alcohol witch can be used for all fuels. This usually happens after running Alco than switching to gas
    Sep 2014
    11
    I've used "Seal-All" as a quick fix before. It's in a yellow tube and you should be able to find it at any auto parts store.https://www.autozone.com/sealants-gl...E&gclsrc=aw.ds
    Jun 2007
    1,047
    I've seen this too and wonder why they don't use the alcohol bladder in all cars so you can run whatever you want to.
    Aug 2018
    5,232
    Quote Originally Posted by matt_s86 View Post
    I have a small cut in a 3 race nose, I wonder if that will hold?
    In my prior agricultural days, a tank manufacture sent a tech out to repair pin holes in some new fert. tanks. It looked like a glue stick, so the tech melted it with a torch and plugged the holes. They never leaked again even with 6,000 lbs of liquid pushing on it!
    Feb 2015
    901
    Seal-All is great stuff for everything from sealing everything from fuel jugs to resticking peeled up graphics edges to a dab on the back side of loosened rivets or bolts. We find new uses for it almost weekly. Just try not to get it on your fingers as it's not the easiest thing to get off unless you like a crust on your fingers for several days.
    Oct 2017
    1,368
    Quote Originally Posted by 50j View Post
    Because it's a 800$ option
    Jan 2013
    4
    CHEMSEAL B2 TANK SEALANT CS3204, AircraftSpruce caries it.
  10. #10
    Jul 2014
    399
    https://www.flexsealproducts.com/ (Just Kidding) Torch and a fuel cell bladder...HELL NO!!
