Results 1 to 2 of 2
Thread: setup help
    Aug 2008
    Cincinnati Ohio
    1,048
    Default setup help
    I'm looking for setup help on adding rear wheel spacers in the rr > Does it tighten or loosen …. Also the same on lr …. Moving it out ? How does the car react to these changes …. Last question in rf ….Moving it out does what to the setup ? I didn't ask about the lf since I was told it doesn't do a lot ? Also is there a setup guide online I can read …. Thanks in advance ...
    Batavia, OH
    13,640
    This assumes the spacer is all you do. Moving a wheel out takes weight off of it and effectively softens the spring. So, move rf out, tighter off throttle, looser on throttle.
    Rear is more complicated because you also have the tires position, compared to the center of gravity location, while pushing the chassis forward. Looking at only that component of it, left out tightens on throttle, right out loosens on throttle. Likely the contribution from the loads will have a greater effect.
    Atomic - 2
