Results 1 to 1 of 1
    Default 2016 UMP Mod sellout
    Late 2016 Hornaday Chassis UMP A Mod with less than 40 nights on chassis. Sweet steering box, Collaspable shaft, Wilwood pedals and master cylinder, Longacre stepper motor gauges, Keyser Birdcages/Jbar/Climber/J bar mounts, Bulldog Readend, Superior fuel cell, Eibach Platinum springs, Penske Shocks, QA1 low friction ball joints, FK rod ends, Wehrs chain limiters, 16v battery,Never bent or on the jig. Mullins 23* Motor with 12 nights since 1st freshening. Dart block, Mullins outlaw aluminum heads, TD Shaft rockers, Titanium valves, Pac valve springs, Lightened Callie's crank, Compstar rods, ARP bolts, Olsen 9 quart oil pan, KSE reverse mount power steering and fuel pump, Aeromotive fuel regulator, KB gas carb , Schoenfield Tri Y headers, New Race-Fan 3 blade composite fan, New FSR radiator, New jones pulleys, Bert transmission...Oil changed after every 2 races only using Shaeffers oil and WIX filters. Will come with spare KSE reverse mount pump, wheels, radiator, carb, etc. Jump in and race this weekend!$20,000 turn key$10,000 for motor $10,000 for roller Message me if interestedMike859-312-0074
