Switched to E85
Switched to E-85 and been told to use some Marvel Mystery oil to the fuel but how about how much per gallon would you use?
use it as directed on the bottle---what ever fuel lube that you use
many moons ago our carburetor builder suggested that we start recommending to our customers that they use a lubricant in the fuel for E85 and oxygenated gasoline's
when making the suggested recommendations I was not specifying how much to use----as with many things racers believe if a little is good then more is better----most times that is not true and is not true with a fuel lube.
we experienced lubricant build up in the carburetors of those who believed "more is better"
use it as directed and it will work the way it should
Brad
www.race-1.com
