Results 1 to 6 of 6
    Apr 2010
    851
    Default camaro lower on metric frame
    will it fit without having to move the fame mounts?
    Nov 2007
    205
    Gen 1 camaro/nova lowers will. From rear steer cars.
    Gen 2 camaro are the same width as Impala lowers.
    Apr 2010
    851
    so like a 75ish camaro like the guys use for street stock cars wont fit a metric monte carlo frame without moving the frame mounts?
    Nov 2007
    205
    That is correct.
    Aug 2018
    5,233
    Back in the late model stock days, we would whack the ears off the lowers and weld a flat plate in its place. Then drill a 1/2" hole in it and install a heim in it. Then you can adjust wheelbase and even caster/camber.
    Apr 2010
    851
    Quote Originally Posted by 95shaw View Post
    That is correct.
    thanks for the info
