Results 1 to 5 of 5
    Ozarks
    775
    Default Tire rule for Luca Oil Topless Friday night
    Tire Rule for Friday, August 20th:
    Left Rear/Fronts - Hoosier Rib (28.5) 1350
    Right Rear - Hoosier (29.0) White Dot 1600 NRM, (29.0) White Dot 1600 NRMW
    *Must use the same set of 4 tires for Time Trials, Heat Races, and B-Mains.
    *For the A-Main, competitors may use 2 new rear tires.
    *Flat tire must be replaced with a used tire of the same compound and construction to retain starting position.
    Batesville is a very abrasive track and very hard on tires. If you come in and change a tire you go tailback you do not retain your starting position. So what does the last sentence mean???
    Dec 2008
    Sheridan Ar
    727
    Probably mean if you have a flat after time trials, you have to run a used tire to keep heat race starting position.
    Mar 2015
    108
    Looks like their gonna burn some tires off tonight. Track is already turning black slick and it's only hot laps.
    Dec 2017
    4,418
    When did bmj get back in a longhorn?
    Ozarks
    775
    I believe he is repping them now.
