L s aluminum engine
I have a disassembled L S alum. engine.The block need's a sleve which I have,needs to be installed.
Comes with a NEW SET OF DYERS BILLET RODS, NEW SET OF RACE TRAC PISTONS,NEW RINGS,NEW PINS,NEW BEARINGS.
THE CRANKSHAFT IS IN LIKE NEW CONDITION,AS IS THE CAMSHAFT.ALSO HAS A NEW COMPLETE SET OF COMETIC GASKET'S
THE REST OF THE PART"S ARE ALL THERE TO MAKE IT A COMPLETE (SHORT BLOCK)
Call any time (513) 868-8998 or (513)305-9951)
Thank's for looking
Many a phone call,all I have is conversation,You can't go wrong at $4500.00
Thanks.
Thanks for all that inquired,Engine has been sold!
This man has another RHS ALU. Block, with bascially the same Equiptment,Exception is it has a fresh Hone,Ready to be put together,only this unit has a complete set of ROLLER LIFTERS,along with the other iems that are listed in the above post
Thanks!
lazermod3
Thanks!
Thanks again to all the 4M looker's.The engine, has been SOLD
