steel head steel block best of everything dynoed fresh 0 laps
  • andy16
    • Jul 2009
    • 310
    358 cid
    4.160 bore bowtie block
    3.28 stroke bryant 42 lb crank
    6.0 carrillo rods
    flat top je custom pistons gas ported slipper skirt
    dart platinum 215 heads angle milled ti hardware psi springs 48cc
    jesel rocker arms less than 1 season on
    comp roller cam
    crower lifters less than 1 season on
    brodix manifold
    cv pan w matched melling oil pump good to +9000rpm
    msd dist
    waterpump
    13.2-1comp
    can be ran on gas or alc.
    dynoed in march @610hp and 485ftlb engine was flawless on dyno this engine has not been installed in a race car. have all build sheets and dyno sheet only the best parts used
    this motor is 100% legal to run anywhere in the country for a late model or modified.
    located in fayetteville nc
    i have 14,000 invested i will consider all offers / trade +cash for a 18-24ft enclosed trailer we went mini sprint racing with the kids help me get them going
  • andy16
    • Jul 2009
    • 310
    updated info
    here is the build sheets dyno sheet and reciepts for engine , serious inquirys i will give you mark battens number he told me he would talk to buyers if needed. his motors just won vms modified last weekend and 4th place in same race. also his motors have won the clr race for the kids in nov and numerous carolina clash races and last year got the clash rookie of the year with damon kotke. his reputation speaks for itself he does not deal in junk.
    if you look at the dyno sheet it tells more than hp and trq you can see the oil pressure and oil temp stay constant thru out the dyno meaning the clearances are good the pump is not cavitating and all went well. on the build sheet you can see the clearances so you know bearing clearance and valve to piston is is correct. and on the reciept you can see all the new stuff like $900 pistons, ati balancer, angle mill heads and dyno. You wont have any questions about this motor. thanks
    • andy16
      • Jul 2009
      • 310
      This motor will be at the WoO race in fayetteville nc friday night if you want to see it in person call or text nine one zero two eight zero one five zero seven
      • andy16
        • Jul 2009
        • 310
        btt......................
        • andy16
          • Jul 2009
          • 310
          if your motor is getn tired here is a fresh one
