Steel Ford Stroker 410w Wet Sump Engine
  • thebreeze72
    • 255
    FRESH OFF DYNO & RACE READY!!..ENGINE MADE 570 HP & 540 FT. LBS. WITH 750 GAS CARB,555 HP WITH 650 CARB,CAPABLE OF 600+ HP WITH LARGER ALKY CARB ! Fresh engine: 9.5" deck 72 Windsor seasoned block w/ steel main girdle...Bored .040 over ,Internal balance 4" stroke 50 lbs. steel Callies dragon slayer crank,Compstar H- beam rods,Mahle forged flat top pistons & rings, Ford Motorsport N351 steel heads "HVH" ported with Ferrea 2.05" intake x 1.60 exaust valves,Comp. solid roller cam & lifters,Jesel shaft rockers,Edelbrock Super Victor intake.Innovators West balancer,MSD Dist.,Aluminum water pump.Best of everything! Great steel block late model,modified,outlaw stock ,engine.....I Have multiple oil pans for most applications also .$9000.00 obo.(724)880-4580 Dave
  • thebreeze72
    • 255
    bump up to the top.
    • thebreeze72
      • 255
      open to serious offers?
