here is a sbc 385 stroker built for late models it is a 350 block worked bored line bored stroker clearenced fitted with a 3.75 stroke lightweight 40 pounds callies compstar crank , eagle lightweight h beam rods srp lightweight .40 over pistons solid roller cam .645 lift 104 centerline, brodix track one heads aluminum 1.5 roller rocker arms crane stud girdle eldebrock 2925 intake msd dist 85551 and 10 mm wires eldebrock aluminum water pump lightweight 6.25 balancer holley 750 carb needs rebuild fabricated valve covers motor made 675 horsepower on dyno when built only has 4 races on it in car can hear it run before bought only thing i am keeping off motor is fuel pump power steering pump and pulleys asking 4500.00 or can keep dist and fuel log and ask 4300.00 any questions or to hear it run dirtnut10m@aol.com or 757-374-3159 thanks frank
