Race Ready 410 UMP Chevy Complete Engine
  • racerman2000
    • Jul 2013
    • 16
    This engine is fresh from the shop It has been Race Preped-Balanced-Blue Printed and is fresh off the dyno and ready to roll I have all build and dyno sheets. DART Little M lightened 4 bolt splayed cap Block with 4.170 Bore and A .010 deck also has DART coated cam bearings & drilled and tapped for dry sump New 4340 SCAT Crank with 3.750 stroke 67.5cc chamber Port Matched Brodix aluminum heads and intake.Heads have oil drain back lines to oil pan & also has water lines in top of intake & comes with swivel water neck and dis-hold down Weiand aluminum water pump with water lines from pump to side of block J & E Pistons with .175 dome (total bob wt 1786 grams) Comp Star 6.125 rods with ARP 2000 bolts Aluminum Valve covers CP 100 Champ Pans Oil Pan This is A very strong engine good enough to run any track in the US at A Great Price $5999.99 !!!!! Call any time 309-948-9980 Ask for Adam
  • boppersims
    • 385
    Where you located?
