Pro Pwer 410 ci all steel roller best of everything dart heads and block
  • racinlm
    • 162
    I have for sale a 410ci Pro Power Modified Engine. Built with the best of everything.
    -New in 2013 with Dart Steel Heads and Dart Steel block.
    -Engine was built originally as a flat tappet engine and run for 8 nights. -Decided in 2014 to change the engine to a roller.
    -Pro Power did a complete freshen, changed pistons, cam, lifters, and valve springs at the time of conversion to a roller.
    -After changing to a roller the engine makes well over 650hp and is very smooth on the power.
    -After freshen the engine was run for 3 nights. Driver ended up not being able to race it for the rest of the season and it has been sitting in storage since then.
    -Engine has only seen Schaeffers full synthetic oil, changed every two nights. Rockers checked every night.
    -This is pretty much a brand new pro power engine with only 11 nights in a modified since new.
    Details:
    ** Callies XL Crank 3.800 stroke, 1640 grams bob weight, Arrow Rods, Dart SHP Block 4.131 bore, JE FSR Gas Ported Pistons, Crower Roller cam Big Block Rocket Journal Cam, Crower Lifters, ISKY Springs, Dart 227 CNC Ported Heads, 13.25:1 Compression, Total Seal Top Rings, Champ Wet Sump Pan, Crower Stud Mounted Aluminum Rocker Arms 1.6, Balancer, Coated Cam and Rod Bearings**
    -Comes with a Willys alky carb, water pump, and msd distributor that was new at the time the engine was new.
    I also have the Crower flat tappet cam and lifters to make the engine IMCA legal.
    Call Johnny at Pro Power for details
    Will Deliver within 100 Miles of Racine, Wi.
    $12,000 or best offer
    Call, message, or text Chris 414-881-5512 Located in SE Wi.
  • racinlm
    • 162
    • racinlm
      • 162
      Awesome Pro-Power Engine. Very little time on the engine. Moving away from modifieds otherwise we would still be racing with this engine.
      • racinlm
        • 162
        Bump Make Offer
