SUPER LATE MODELS $6,000 TO WIN! $500 TO Start!
50 LAP SUPER LATE MODEL ICE BOWL CHAMPIONSHIP!
RULES: OPEN MOTOR - 2300 LBS. - ALL OTHERS - 2,250 LBS.
TIRES: Any 11x92 max tire * 1lb. per lap burn off.
SOUTHERN ALL STARS BODY RULES APPLY - ALL SPOILERS 8â€. $100 Entry Fee.
Open Practice Thursday & Friday - Qualifying (2 laps) and Heats on Saturday - Consys and Feature on Sunday
CRATE MODELS $3,000 TO WIN $250 To START!
Weight: 602 / 2,200lbs ; 604 / 2,300lbs NESMITH BODY RULES
Tires: Crate 21; Crate 55; Spec 21; Spec 55; Spec 1350 OR Spec 1600
CRATE ENGINES MUST NOT BE ALTERED, MODIFIED OR CHANGED FROM FACTORY SPECS.
ENGINE MUST HAVE AUTHORIZED APPROVED SEALS. Gas or Racing Gas! E85 OK! NO alcohol.
ENGINE SERIAL NUMBER MUST BE CLEARLY VISIBLE TO TECHNICAL INSPECTORS. $100 Entry Fee!
SPORTSMAN (Ltd. Late Model): $2,500 TO WIN $200 To START!
2350 lbs. Anytime * 362 cubic inch max, * ALL steel motor * flat top, steel heads- no porting or
polishing. Dry Sumps are Allowed!! 602 OR 604 crate motor 50 lb weight break! SAS body rules! Any 11x92 max tire. Gas only. All Spoilers 8". $75 Entry Fee.
Open Practice Thursday & Friday - Heats on Saturday - Consys and Feature on Sunday
BOMBERS (Thundercars): $1,200 TO WIN! $100 To Start!
2900 lbs anytime. All steel motor. Flat top, hydraulic or flat tappet. Steel heads no porting or polishing. Bodies must be stock appearing. Aftermarket stock type steel and aluminum bodies w/6" max rear spoiler OK. Aluminum wheels add 100 lbs. Any 11x92 max tire. Stock frame from front to center of rear end. Frames must have stock front clip. Tubular rear OK. Quick Changes OK. $30 Entry Fee.
MINI STOCK (PONY) : $1,500 TO WIN $100 TO START!
KAJUN MINI STOCK ASSOCIATION EVENT. Entry Fee: $50
Open Practice Thursday & Friday - Heats on Friday - Consys and Feature on Saturday
STREET STOCKS: $1,000 TO WIN! $75 To Start!
$20 ENTRY FEE. The 2014 Ice Bowl Rules Will Be Posted In The Next Few Days.
HOT SHOTS (Buzz Car): $500 TO WIN! $50 To Start!
TALLADEGA SHORT TRACK RULES APPLY! NO ENTRY FEE!
Open Practice Thursday & Friday - Heats On Friday and Feature Event On Saturday
