Spoiler advantage at Screven Winter Freeze
  • txracer
    • 244
    Will the 12 inch spec . 525, all steel and whatever else spoiler advantage be allowed at the winter freeze?
  • flagone
    • 2861
    2010 Southern All Stars weight and body rules.
    • txracer
      • 244
      Ok thanks , just seen on the website where sas , lucus and woo bodys, but that clears things up thanks.
      • Rocky
        • 3218
        12 inch spoiler for who????? with what motor?
        Guerilla Racing Junkies.
        Shovel on a little more coal, then when we cross white oak mountain, watch 97 roll!
        The problem is the gall dang motors.
        • slick01
          • 3599
          525 and Spec stuff I am reckoning Rocky though the blade has been cut down on the spec stuff lately.
          43 races this year.
          Tulsa Expo- 5, Volusia- 3, Bubba Raceway- 3
          Dillon Speedway- 1, Myrtle Beach Speedway-1, Hickory Speedway- 1
          Southern National- 1, Lincoln Speedway-2, Williams Grove Speedway-2, Indiana State Fairgrounds-1
          Anderson (Indiana) Speedway-1, Indianapolis Motor Speedway- 1
          Bloomington Speedway-1, Lawrenceburg Speedway-1
          Kokomo Speedway- 1, Port Royal-1, Limaland- 1
          Eldora- 2, Knoxville- 6, Oskaloosa-2, Attica-2, Wayne County-1
          • F22 RAPTOR
            • Jul 2010
            • 1023
            Per latest SAS rulebook release on website.
            WEIGHT/ENGINES:
            • All weights include driver and are after qualifying.
            • Unlimited cubic inch with aluminum heads and aluminum block - 2300 lbs.
            • Unlimited cubic inches with all cast iron block and aluminum or steel heads - 2200 lbs.
            • 362 cubic inch MAXIMUM with flat top pistons, any camshaft, any steel cylinder head and steel block - 2150 lbs.
            • V-6 engines – 2350 lbs.
            • The GM 602 and 604 SEALED crate engines will be allowed at 2150 lbs.
            • GM Performance Parts CT525 Crate Engines will be allowed in Southern All Stars Dirt Racing Series competition. The engine must remain as a sealed unit per GMPP specifications. Any variation from this would disqualify the engine’s use. The GMPP CT525 engine will be allowed to have a 12-inch spoiler and compete at the 2150 “spec” weight. No other body modifications or changes will be allowed.
            All engines EXCEPT the GM Performance Parts CT525 Sealed Crate Engine may only utilize and operate with a single magneto or single distributor ignition system. Coil-pack or distributor-less type ignition systems will only be allowed on the Sealed GMPP CT525 engine.
            • SPEC ENGINE OPTIONS • SAS recognized SPEC Engines will carry a weight of 2150 lbs.
            • SAS recognized SPEC Engines will have the 12 inch spoiler option specific to the SPEC Engine type.
            #77 Leon "Slick" Sells
