2004 black front end rocket updated at rocket 2011. Car was not raced 2011 and ran last two races of 2012
season 1st and third place finishs. Ran first two races of 2013 season 1st and 2nd place finishs. I just cant
afford to fund the car out of my own pocket anymore have to sell but dont want too. New black powder coat. New
chromemoly rocket front bumper,new back bumper, new front and back tbars, new door bars and doorbar trees, new
Aluminum slotted body braces,new double spring steel heat shrinked. Complete new black body with 4 races one
small ding on ds over tire. Aluminum cone washers on body. Carbon fiber roof cap. Md3 nose with red lower
valance.Fiber glass roof. No seat sold it. New Mullins oil cooler with new stainless screen protector. New
push on oil cooler lines with black an fittings. New allstar oil t block fitting. New black joes aluminum
steering wheel. Woodward collabsable steering shaft. New lower steering shaft and ujoints. New sweet 4.0
steering rack with built in servo. New red transmission shifter. Tel-tac, Quickcar gauges,quickcar battery
disconnect,quickcar brake bias gauges. New willwood clutch and brake pedal assembly. Birkoffer fuel pedal. New
fire extinguisher. New simpson belts. New brake bias adjuster. New Wilwood electric 3 way brake switch. 4 new
scalloped 1.25 rotors. 4 new wilwood superlite calipers. All new braided brake lines. All new black medal
brake lines and new fittings and mounts. New polymatrix brake pads. Black wilwood hubs with new black axle cap
and wheyrs machine push in aluminum caps for front.Car come with standard shocks or A set of ohlins lmj shocks
by custom suspension with mounts and shock covers for 1500 more includes traction shock. 4.86 winters rear end
with black axle tubes. Rocket bearing birdcages with new bearings. Twm slotted jbar frame mount and twm pinion
mount. New cv products aluminum jbar. New PRC double vented rearend filler. New Mikes custom tanks fuel tank
panel. Quick connect battery charging connection. New rocket liftbar, New rocket top and bottom brackets. All
rodends on car are new black steal. All new ppm black lingage bars. New teflon coated rod end on steering.
Comes with wiles steal drifeshaft. Afco 6th coil and 5th coil mount. New 22 gallon jaz fuel cell powdercoated
black with custom cage.Rocket adjustible midplate. All new howe balljoints. New howe blue max upper aframes.
Rocket 1 piece lowers. New rocket spindles. New Allstar shaker screen. 1 season old allstar triple pass
radiator with honey comb protector. Appleton finned power steering resevoir with filter. All new power
steering hose. New fuel line with red jegs fuel filter housing with new black an fittings. 6al msd which was
sent back to msd and checked out. Msd blaster coil. All wires, bolts, fittings are new. The car has been went
through ground up. 3 nonbeadlocks and one beadlock with 1300 Hoosier tires. 7500 cash or 1500 more with ohlins
shocks
shocks
