Atomic Speedway Results May 24, 2014
  • Unclebig
    • Oct 2007
    • 1266
    Atomic Speedway Results May 24, 2014 FOR IMMEDIATE RELEASE
    Chamberlain Wins 7th in a Row!
    Stinson Doubles at Atomic, Eberts "Land of 10,000 Lakes" Modified Winner
    By Scott Wolfe
    CHILLICOTHE, OHIO-The year's biggest crowd turned out to support the KC/Atomic Speedway 2014 Hall of Fame Inductions and a great night of racing at Brad McCown's Atomic Speedway Saturday night. All three features went right down to the wire with Richmond, Indiana driver Duane Chamberlain capturing the $2,500 to win Gullion Enterprises AMRA Late Model main. Jimmy Stinson, Vandalia, Ohio was a repeat winner by a car-length over Greg Wilson for the $2,500 win in the 410 sprint main, while Lake Shore, Minnesota driver Dan Ebert claimed the Advanced Services AMRA Modified main.
    A solemn, but memorable ceremony honored past racing legends and race contributors for the Atomic Speedway 2014 Hall of Fame inductions. Inducted into the hall were Spike Spears, Jim Meeker, Harry and Tony Martin, Dale Jones, Gerald Palmer, and the Karshner family.
    Nine exciting heat races saw four photo finishes. The preliminaries set the stage for the night's feature events. A quality field of cars and drivers filled the pits for one of the best racing events of the year. Next week, May 31 is Fan Appreciation Night with a $5 admission.
    "Insane Duane" Chamberlain powered his Darge Engines/Rocket Chassis past early leader Delmas Conley on the 24th lap, then outdistanced the field to claim his second Atomic Speedway win of the year. The win was also Chamberlain's seventh win in a row for the Richmond, Indiana driver.
    Delmas Conley jumped into the early lead and for a time started to check out, but as the race progressed Chamberlain reeled in the veteran Conley for what proved to be a classic dog fight for the middle portion of the race. By lap 12 Chamberlain dove low under Conley, setting the stage for a five lap shootout between the two veteran drivers. Chamberlain and Conley swapped slide jobs on both ends of the track during those five laps and at one point Chamberlain leaned on Conley hard upon the turn four exit.
    Conley came back to cop the lead again as the crowd rose to its feet for the great, great show they witnessed. Chamberlain then took the lead, but Conley came right back while a just as exciting battle had developed for third between Devin Moran and Jackie Boggs. That race-long battle ended on lap 17 when a racing deal sent Moran hard into Boggs. Boggs' mount was disabled and Moran went to the tail.
    Earlier Jason Montgomery had been shuffled back to seventh, but he climbed back into the mix behind Conley and Chamberlain. Again the duo went at it tooth and nail with fast-timer Chamberlain taking over for good on lap 23. Two laps later Conley went pitside with mechanical problems.
    R.J. Conley started 13th but now had worked into a top five. Moran had a similar fate with a blast from last to the top eight after his earlier spill. Oliver jumped the cushion while running a strong third, but recovered for a top ten, opening the door for Rod Conley and a good run from third generation driver J.T. Conley. John Whi tney, Billy Guillon, and Kevin Wagner had strong runs as well amid the star-studded field.
    Rounding out the top ten were Chamberlain, R.J. Conley,Jason Montgomery, Rod Conley, J.T. Conley, Greggie Oliver, John Whitney, Devin Moran,Billy Guillon, and Kevin Wagner. R.J. Conley was the hard charger with a 13th to second place run.
    In the 30-lap Sprint car A-main Jimmy Stinson, bobbed and weaved through traffic and blitzed to what seemed an insurmountable lead. As the race unfolded, however, former All-Star Champ Greg Wilson began to reel in the May 17th winner, and closed the gap to within a car length by the time a lap 22 caution waved for a spinning Nate Reesor. Earlier Wes McGlumphy had a great run stymied when he made contact with another car and spun.
    The battle heated up between the two front runners after the caution. Eight laps of helter skelter, high anxiety racing fueled the fire to the finish. Wilson tried several slide jobs, the most severe a high-speed flash through two and into the front of the high flying Stinson. Stinson somehow regained control and bored into three past Wilson on lap 27. Wilson banged the front chute wall in the chase and scrubbed off just enough speed to give Stinson a little breathing room.
    Wilson fought back under Stinson twice and challenged off turn four, but Stinson held on for the popular win.
    "I saw the 20 car out there on the scoreboard during the caution and knew he would be fast," said Stinson. "Then at last he scared the crap out of me and I scared the crap out of myself, but that's what racing is all about. I hope we made it exciting for the fans."
    "The track keeps getting better every week and the fans keep coming out better. I'm glad to see this deal at Atomic going good and thank Jamie Miller for putting together a great race car."
    Jimmy Nier, aboard his 360 mount, fought from 21st to 9th to earn Hummel Factory Kahne's Racing Shock "Hard Charger" award. Kory Crabtree was nearly as impressive with 16th to tenth place run.
    Nathan Skaggs had a great run from eighth to third place in an impressive run, while Todd Kane and Josh Davis consistently ran in the top five. Rounding out the top ten behind Stinson were Greg Wilson, Nathan Skaggs, Todd Kane, Josh Davis, Ryan Broughton, Ryan Myers, Aaron Higgins, Jimmy Nier, and Kory Crabtree.
    The 25-lap Advance Services AMRA Octane Modified main was a barnburner. Dan Eberts took the early lead, but every step of the way Luke Jordan was in the wake. Jordan reeled in Eberts and grabbed the lead on lap twelve with Eberts now the hunter, not the hunted. Jordan led two close, side-by-side laps then Ebert blasted into the lead.
    Ebert worked traffic to perfection, but Tim Tribby was on the move. Tribby first bagged Jordan, then Shawn Holiday. Pinkerton recovered from a near-spin at mid-race to finish fourth ahead of Jordan, Jimmy Lennex, and Doug Adkins.
    Tribby made a late race bid for the lead, but Ebert's move in traffic gained him enough turf to pull off the close win at the finish.
    "The middle part of the race got pretty exciting out there", exclaimed Ebert. "The car worked anywhere I put it and I dedicate this win to Jackie Boggs. Our heavy track set up and middle -heavy set ups have been great, but our slick track stuff has been mediocre. Jackie got me sorted out and I give this win to him."
    Rounding out the top ten were Dan Eberts, Tim Tribby, Shawn Holiday, Dave Pinkerton, Luke Jordan, Jimmy Lennex, Doug Adkins, Jason Montgomery, Phillip Bapst, and Rob Stambaugh. Phillip Bapst was the hard charger in a 16th to 9th place run.
    Jason Edwards, Port William, Ohio won the Enduro.
    For more information please call 740-703-9749 or 740-663-4141 or visit the Atomic Speedway website at <<< www.atomicspeedway.net >>> Atomic is located 12 miles South of Chillicothe, Ohio off SR 23, two miles out Blain Highway between Chillicothe, Ohio and Waverly, Ohio at Alma.
    Atomic is a Hoosier only track. Check the website for rule details and the NDRL site for the weekend tire rule for late models.
    Coming Events!
    May 31- FAN APPRECIATION NIGHT #1 Only Five Dollar Admission !! Sprints, AMRA Late Models, AMRA Modifieds, Street Stocks
    June 7 No Racing
    June 14- Veterans Night: Sprints, AMRA Modifieds, Street Stocks, Sport Mods
    THE SUMMARY:
    PINE TREE TOWING AND RECOVERY (23)
    Fast Time: Greg Wilson 12:042
    Heat One- Greg Wilson,Wes McGlumphy, Ryan Broughton, Aaron Higgins, Eddie Slone, Kory Crabtree, Jeff Conrad,Mark Coleman
    Heat Two-Jimmy Stinson, Mark Imler, Nathan Skaggs, Jesse McCreary, Nate Reeser, Kevin Sabo, George Hawkins
    Heat Three-Todd Kane, Josh Davis, Ryan Myers, Kirk Jeffries, J.T. Stapp, Bob Tucker, Jimmy Nier
    Feature: Jimmy Stinson, Greg Wilson, Nathan Skaggs, Todd Kane, Josh Davis, Ryan Broughton, Ryan Myers, Aaron Higgins, Jimmy Nier, Kory Crabtree, Kirk Jeffries, Mark Imler, Nate Reeser, Jesse McCreary, Eddie Slone, Wes McGlumphy, George Hawkins, J.T. Stapp, Kevin Sabo, Jeff Conrad, Mark Coleman, Bob Tucker.
    GULLION ENTERPRISES AMRA LATE MODELS (20)
    Fast Time: Duane Chamberlain 13:794
    Heat One- Jackie Boggs, Duane Chamberlain, Rod Conley, Mick Sansom, R.J. Conley, Rod Evans, Justin Carter
    Heat Two- Devin Moran, Jason Montgomery, J.T. Conley, Kevin Wagner, Graylin Prince,Kevin Wagner, Jeremy Berwanger,Dwain Pick
    Heat Three-Delmas Conley, Greggie Oliver, John Whitney, Billy Guillon, Avery Taylor, Jay Helton
    Feature: Duane Chamberlain, R.J. Conley,Jason Montgomery, Rod Conley, J.T. Conley, Greggie Oliver, John Whitney, Devin Moran,Billy Guillon, Kevin Wagner, Avery Taylor,Jay Helton, Dwain Pick, Delmas Conley,Jackie Boggs,Justin Carter,Graylin Prince, Rod Evans, Jeremy Berwanger, Mick Sansom
    ADVANCE SERVICES H & C AMRA MODIFIEDS (25)
    Fast Time: Dan Ebert 15:445
    Heat One- Dan Ebert, Luke Jordan, Tim Tribby, Jason Montgomery, Brandon Oliver, Phillip Bapts, Glenn East, Jim Lemaster, Dave Kelly
    Heat Two-Dave Pinkerton, Larry Holbrook, Jimmy Lennex, Donnie Miller, Jason Cottrill, Travis Hightower,Rick Hensley, Greg Oliver, George Neely
    Heat Three- Doug Adkins, Brian Whiteman, Shawn Holiday, Jeff Votaw, Rob Stambaugh, Chris Tolle, Glenn Keaton, Bob Crace, Jr.,
    B-Main: Philip Bapst, Bob Crace, Jr., Glenn Keaton, Chris Tolle,Travis Hightower, Glenn East, Jim Lemaster
    Feature: Dan Eberts, Tim Tribby, Shawn Holiday, Dave Pinkerton, Luke Jordan, Jimmy Lennex, Doug Adkins, Jason Montgomery, Phillip Bapst, Rob Stambaugh, Brian Whiteman, Jason Cottrill, Brandon Oliver, Jeff Votaw, Donnie Miller, Bob Crace, Jr., Glenn Keaton , Chris Tolle, Larry Holbrook, Travis Hightower.
