FASTRAK Technical officials have issued the following Technical Bulletin Updates. The updates will be added to the front of the 2018 Rule Book.
March 16, 2018
2018 Technical Bulletin Update
PAGE 9 - SAIL PANELS
Left and right sail panel bottom may be inboard 2 ½ inches maximum from top of quarter panels.
2018 FASTRAK Technical Bulletin Update
March 15, 2018
PAGE 9 – BODIES
Must have full fender left and right
No fender Hump, Top of fender must be flat.
Lowest point between left and right of outside edge of body at front fenders may not exceed 4 inches. No Tolerance.
This will be measured from the lowest point between the rear of the air filter and the rear hood pins
Sail panels must have minimum of 3 inches of gap at deck where it meets the spoiler blade.
Diagram will be updated to reflect this change.
PAGE 9 – INTERIOR
Interior body work may be dropped a maximum of 5 ½†inches below the door.
PAGE 14 - SHOCKS/ SPRINGS
Standard linear steel Barrel type springs are permitted
PAGE 5 - ENGINE SEALS, PAGE 6 – ENGINES, PAGE 6 - WEIGHTS
NESMITH Seals with aftermarket parts must add 50lbs
Any questions please contact one of the technical directors listed in the rule book.
March 16, 2018
March 15, 2018
PAGE 9 – BODIES
PAGE 9 – INTERIOR
