Lucas Oil at 300 Raceway (Farley, IA)
  • Shiny Side Up 18
    • May 2016
    • 12862
    #61
    33 to go. Richards running JD down!
    • Shiny Side Up 18
      • May 2016
      • 12862
      #62
      Caution with 34 to go as Don O'Neal stops on track. He is pushed off the track. 49 14 1erb ou812 1s
      • mcarter815
        • Nov 2016
        • 1690
        #63
        Track has widened a little, but it's a dust bowl.
        • Shiny Side Up 18
          • May 2016
          • 12862
          #64
          I was drilled in the shoulder by a rock on the last restart.
          • Shiny Side Up 18
            • May 2016
            • 12862
            #65
            Don O'Neal going off on the hook.
            • Shiny Side Up 18
              • May 2016
              • 12862
              #66
              Birkhofer has a flat under yellow.
              • Shiny Side Up 18
                • May 2016
                • 12862
                #67
                Back to green with 33 to go. JD leads, Terbo bottom, Richards top. Birkhofer continues.
                • intel8
                  • May 2008
                  • 827
                  #68
                  Farley sharp little rocks taking its toll on tires!
                  • Shiny Side Up 18
                    • May 2016
                    • 12862
                    #69
                    Caution with 31 to go as Tyler Bruening has a flat. 49 1erb 14 1s 40b. McCreadie from 20th to 8th.
                    • thexfactor0210
                      • 1561
                      #70
                      Man 31 to go and about 8 flats already!
                      • Shiny Side Up 18
                        • May 2016
                        • 12862
                        #71
                        Back to green with 31 to go. JD leads, Richards bottom, Terbo top.
                        • Shiny Side Up 18
                          • May 2016
                          • 12862
                          #72
                          30 to go. Top 7 single file.
                          • Shiny Side Up 18
                            • May 2016
                            • 12862
                            #73
                            Caution with 26 to go as Chad Simpson has a flat. 49 1erb 14 40b 71 39 1p 50 32s 12
                            • Shiny Side Up 18
                              • May 2016
                              • 12862
                              #74
                              Back to green with 26 to go. JD leads, Richards top, Terbo top. Owens also had a flat.
                              • TUTY
                                • May 2012
                                • 1243
                                #75
                                Sounds like a dumpster fire.
