Tire rule for Luca Oil Topless Friday night
  • JimBo
    • 812
    Tire Rule for Friday, August 20th:
    Left Rear/Fronts - Hoosier Rib (28.5) 1350
    Right Rear - Hoosier (29.0) White Dot 1600 NRM, (29.0) White Dot 1600 NRMW
    *Must use the same set of 4 tires for Time Trials, Heat Races, and B-Mains.
    *For the A-Main, competitors may use 2 new rear tires.
    *Flat tire must be replaced with a used tire of the same compound and construction to retain starting position.
    Batesville is a very abrasive track and very hard on tires. If you come in and change a tire you go tailback you do not retain your starting position. So what does the last sentence mean???
  • slmcrewchief99
    • 738
    Probably mean if you have a flat after time trials, you have to run a used tire to keep heat race starting position.
    • Minny Lakes
      • Mar 2015
      • 124
      Looks like their gonna burn some tires off tonight. Track is already turning black slick and it's only hot laps.
      • Dlmfan123
        • 4520
        When did bmj get back in a longhorn?
        • JimBo
          • 812
          I believe he is repping them now.
