Lucas Oil
    • 16409
    #121
    Fail to properly address a close finish before it happened.
    So are you saying the drivers have never been told how they would determine a winner under these circumstances?
      • 14310
      #122
      Their process is horribly flawed. It became too obvious, finally. They might as well flip a coin if the finish is within .008 second.
      Just because you apply computing to something, that alone does nothing to improve accuracy or integrity to the process. We've all heard of garbage in, garbage out.
        • 16409
        #123
        Ok but it's not like they did something nefarious.
        I'm more curious did the drivers know how a race would be determined if that situation ever came up and if they did that's really how that matters. I mean it's their money on the line and some do this for a living.
        • jog49
          • 2551
          #124
          But . . . . if the scoring loop is not buried in exactly the right place . . . . . . . the only visual the drivers have is the flag stand and the flagman.
          • Josh Bayko
            • 8737
            #125
            It’s highly unlikely that any of these scoring loops at dirt tracks are at an exact 90 degree angle across the track. Any deviation from that is why these close finishes often have the wrong actual winner.
            Guerrilla Racing Junkies!
            • jog49
              • 2551
              #126
              Yep! I'm surprised the deer hunting crowd hasn't advocated for a trail cam yet.
              • Highside Hustler25
                • 12920
                #127
                This !!!!!
                8/13/16
                  At the end of the day, all I can say is great race. Two outstanding drivers put on a show. My bottom line would be what Hudson said. He slipped on the last lap and let Bobby get to him and that is what happened. Not that Hudson wasn't upset losing the race.
                  It went from a clear win to almost a coin flip. Congrats again to both drivers who are at the top of the sport along with JD, and Ricky.
                  • jog49
                    • 2551
                    #129
                    "What's wrong with making the finish line in the exact same location of the timing and scoring loop."
                    Apparently, that's where it was, and in this day of technology, it's just plain stupid.
                    Why not put the timing and scoring loop at the finish line that has been used since the beginning of time? The official start of a race is at the flag so why isn't the finish of a race at the same place? What other form of racing, from point A to point B uses a transponder to determine a winner? NASA isn't looking to hire the people who made this decision and the rumor mill says the guy that buried the scoring loop was high as a kite!
                    • mnwriter
                      • Aug 2008
                      • 7
                      #130
                      So here is part of the equation none of you think about obviously.
                      If you race more than one class of cars each style of car has the transponder in a different position based on the series/sanction rules. The track in question typically has the modified as their main class. Maybe they figured the distance of standard mounting location of the transponder to the flag stand so the nose of the car crosse the flag stand at the same time as the transponder.
                      Plus even though they dictate location of transponders on all cars for the late models per Lucas rule book I would bet it doesn’t indicate tip of nose to transponder distance so if you look at photos O’Neils nose to front tire looks longer than pierce etc. they are all built different so the transponder is actually the best way to handle the scoring.
                      Knowing how the connections are in waterproof boxes for the loop to the scoring tower you don’t have room at the cemented in flag stands at most tracks to be able to put the loop in the same place as the stand anyway so most tracks found what they figured would be the best average distance for their classes to put the loop so it was close to triggering as the cars crossed the finish line.
                      • jog49
                        • 2551
                        #131
                        You made every bit of that story up, didn't you?
                          • 14310
                          #132
                          Mnwriter,
                          You know what's in the Lucas rules? Tip of nose from front wheel center. You know why? That is a performance advantage. You know what isn't in the rules? Transponder location. It's a verbally given general location on the chassis that isn't in exactly the same point on all cars when referencing the tires or any other part of concern.
                          • over4T
                            • Feb 2015
                            • 1084
                            #133
                            We got bit this past weekend by the transponder location. Our touring Pro Stock group is like most in that location is vague. In our qualifier we took 4th according to the transponder and 5th by less than O'Neal did over Pierce. Competition director came over and talked to both of us after we scaled to work things out with us and our friend. We agreed to move our transponder back a few inches and took the 5th. No big deal? Well our group takes top 4 from 2 heats and complete redraw for those 8 for the main. Guy we "beat" drew a 3 and ended up finishing a strong second. We started 9th and pretty much stayed back there until the last corner when we got banged for 11th. Didn't exactly make us happy but we're just hobby racers, If we did it to put meat on the table I'd feel different.
                            • Jim11h
                              • 1501
                              #134
                              This is why we'll eventually see camera's calling balls and strikes. Things pretty dead when got 7 pages for this nonsense. Most tracks start finish line is one side or other of flag stand and been this way for decades. Scoring tower needs direct sight of line to score close races back before we allowed technology to over take. I will say the most ironic thing of all this is almost every one was swinging from lucas short hairs and now they're doing an about-face. If the rocket would of won all the longhorn chassis hoes would be squealing foul, but then again it was pierce so we see their own division and attack of transponder that they'll download app and watch for results as gospel on other days ending in Y
                              • over4T
                                • Feb 2015
                                • 1084
                                #135
                                Also broke a pretty nice little streak we had going; two wins and 5 other top threes in our last 7 races at tracks in 3 states. Time to get with it and start on another streak hopefully. The eternal optimism of racers in an often frustrating sport. Over 60 years doing this and it never gets any easier.
